2023+ g90 coilover conversion
Willbe
No Genesis Yet!
Basically IAM in the market for a 2023+ g90 cpo. I love everything the e-Sc adds except the air suspension, so when it brakes like it always does I would like to see what's out there. My mother had a Lexus LS that had air suspension and she had to get it replaced like 4 times. Not sure if technology improved where they reliable but I won't get my hopes up.
Also does anyone have a high mileage 2023+ g90? I would love to know about your repair and maintenance history with the car
I'd imagine mechanically, the coil suspension from the base model will bolt up just fine. Your problem will be the electronics. You'll get all kinds of warning lights and chimes about a failed air suspension unless you code the air suspension out of the system. Might also need a different suspension controller out of a base car for the ride modes to work with the replacement electronic struts/shocks. You'd need to code in the spring suspension and probably also program the content theft detection. These cars are not hacked like BMWs, which means you won't be able to code it yourself without extremely expensive typically dealer-only equipment and a subscription. Not even sure if dealer equipment would allow you to code in options that didn't come on the car, meaning it might ask for a VIN and knows what options the car is supposed to have. It might be possible if the height sensor isn't connected to CANBUS or some kind of bus, that there's a way to trick the suspension controller into thinking everything is fine, but almost every part is networked these days.
By then Arnott Industries will have both reman air replacements as well as conversions which will include the alert-defeat. They have been the industry leader for air ride rejuvenation for decades. It's too early now, however - the units aren't failing yet, so they have no stock. Even if they are failing - they are under warranty for 5/60, and if you are keeping it long enough for the parts to wear out & fail then that means you bought the platinum factory warranty or CPO to extend the B2B coverage out to 10/100, right?
I wouldn't hold my breath on the Air-to-Coil suspension conversion kit. Arnott still doesn't have one for 2016+ BMW G12 or 2014+ Mercedes W222 which are both far more popular than 23+ G90s.
Man I so do miss my air suspension - I had an LS460 with air and had it for 6 years. Never had a problem. Replaced with my 21 g90. I miss my air suspension so much that I have been considering replacing my 21 with either a newer model or a late model LS460.
You'll have to let me know if you do that, as I may be in the market for a white 90. :)
I have replaced one front strut, on warranty but they told me the part price which was astronomical, one air suspension shock absorber 5600 $ part alone without labour, but the lower models does not have air suspension so I think going all coils is doable
