Acpantera
- Nov 10, 2018
- Genesis Model Year
- 2023
- Genesis GV60
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
And it came with the O ring and crush washer?Here is what I used in my G70 sport. View attachment 27753
If you care, take a good look at the end of the OEM filter when you take it out. When you run your finger around the hole that goes into the filter housing first, you'll feel that the paper end cap hole is not really round, the paper does not seal well around the nozzle in the housing. Go get a wix or Napa filter and compare side by side with the oem filter for your self. Food for thought.... if you had an engine oil related problem, It would be illegal for the manufacturer to deny warranty because you used an after market, correctly spec'd oil filter, when the defect was in materials or workmanship of the component that failed.I only buy the filters from the dealer. I service my car, not the dealer. I bought my G80 that came with
the 3 years of free service. Car now has 38K now but has not been to the dealer for any services.
I want it done right.
Yes Sir. Filter had the same markings and came from South Korea. Everyone should remember Genesis does not manufacture filters. Filter manufacturers do that. Those who sleep better if the filter box says Genesis, your choice. I’ve never used a Chevy filter, a Ford filter, a Nisson filter. Always used name brand filters, done my own oil changes since age 16 using quality name brand oil. Never had an internal engine issue and sleep good at night knowing I did the work using trusted brands and not some dealer grease monkey who you don’t really know what the hell they are doing. To each his own.And it came with the O ring and crush washer?
I agree with you about 99%. There was one of the engines in an older model that had some problems with non-OEM filters. Perhaps someone will chime in with details on that.Yes Sir. Filter had the same markings and came from South Korea. Everyone should remember Genesis does not manufacture filters. Filter manufacturers do that. Those who sleep better if the filter box says Genesis, your choice. I’ve never used a Chevy filter, a Ford filter, a Nisson filter. Always used name brand filters, done my own oil changes since age 16 using quality name brand oil. Never had an internal engine issue and sleep good at night knowing I did the work using trusted brands and not some dealer grease monkey who you don’t really know what the hell they are doing. To each his own.
