I have a couple of questions:thanks for that. do you know the overall dimentions of the engine??
They both have 6 gears. The ZF is also used by BMW and some other German cars and is a little more robust and more appropriate for the V8 and V6 Coupe, but I would not necessarily say it is better than the Aisin (Aisin makes transmissions for a lot of cars, including some Lexus--they are 50% owned by Toyota).thanks for that,
do you know what gearbox is better and how many gears the both of them have??
thanks for that,
There are many Kia and Hyundai cars that use the 3.8 lambda (Kia and Hyundai are mostly owned by the same parent company). But not all the other vehicles which use the 3.8 are RWD and I only the Genesis Sedan uses the Aisin 6-speed RWD transmission. There usually other minor differences in the various implementations of the 3.8 lambda.hi again. we have done some research and we think that the kia grand carnival has the same engine. i was just wondering if anyone knew this for sure? also i was wondering if the manual bell housing was seperate from the gearbox housing in a rear wheel drive and what car i would find one in??
thanks
Yes. My point is that I believe that the only 3.8 Lambda engine that uses the Aisin RWD 6-speed is the Genesis Sedan. The 3.8 Lambda used on the coupe has other differences besides the tranny since it has slightly different HP rating (probably minor differences in intake or exhaust).the Coupe v6 auto uses the ZF - and Aisin for the Sedan v6 and i4 coupe, respectively
I could be wrong, but I was not aware that manufacturer HP ratings of engines were dependent on the transmission (although some HP ratings at the drive wheels take that into account).I would think the ZF would be more efficient than the Aisin, thus most of the difference. Maybe some from the intake or exhaust note. Would be interesting to put the B600 vs the ZF6HP26 on that note
