5.0 non R-Spec fuel consumption, reviews?
dcuccia
Is anyone aware of real-world fuel economy reports for the new NON R-Spec 5.0L V8 trim level?
I found this list which puts it in-line with the 4.6 (17/26/20).
Also, if anyone is aware of a review of the new model that would also be appreciated. I was surprised that the Hyundai site had the 5.0 and 5.0 R-Spec at exactly the same numbers in terms of HP and torque - just the tires and stabilizer bars seem to differentiate them. Suspiciously, though, if you "compare by pictures", both vehicle pictures show the R-Spec badge...
Looks like the new 5.0 (non R-Spec) gets same gas mileage as the 4.6 (both 1 mpg better than R-Spec), but has the same increased HP as the 5.0 R-Spec. That would not surprise me since the GDI is more efficient, and I suspect that the difference is the transmission shift points between the R-Spec and 5.0 non R-Spec that accounts for the 1 mpg difference in fuel economy.
In addition to the stabilizer bars, I think there are also differences in the springs/shocks, and maybe amount of steering assist, among some other minor differences.
I wouldn't make too much of the observation about the photos. I assume those are EPA certified numbers.
Here are the extra things that come with the R Spec over the regular 5.0:
• "R-Spec" sport transmission, suspension and steering calibrations
• 0.6" larger front brake rotors
• 1mm larger front and rear stabilizer bars
• 19" wheels (vs. 18")
• 22 extra lbs of curb weight
• 1 MPG worse fuel consumption
• Dark chrome headlamp inserts
• Rear "R Spec" badge
• "R Spec" embroidered floormats
• Black/Charcoal-colored simulated woodgrain trim (vs. brown)
• No simulated wood trim on the steering wheel
• Available Bridgestone Potenza S-04 Pole Position summer performance tires option (who cares, just buy them yourself for way cheaper)
• No white!!! Only 3 exterior colors available: Black, Titanium & Platinum
• Only black interior available
• $1,000 less cash in the wallet​
thanks for the summary.
the 19 inch wheels probably accounts for the 1 MPG penalty.
The diameter of the 18" and 19" wheels (with tires mounted) is almost the same. My guess is that transmission shift points are different.
According to reviews I have seen, the reviewers were told by Hyundai that spring and/or shock rates are different between the 4.6 and R-Spec. The reviewer comments about the R-Spec vs 4.6 suspension feel are consistent with those kind of changes (in addition to 1mm stabilizer bar increase). I don't know for sure about the 5.0 vs R-Spec, but I suspect the 5.0 has the same suspension as the 4.6 (and different than R-Spec).
Correct. And the difference in consumption between the 5.0 and the R-Spec is in fact the more "aggressive" sport-tuned gearing.
The wheels add approximately 20 lbs to the rig.
Definitely the shift points are higher in every gear on the R-Spec vs. the 4.6 (and I assume the non-R-Spec 5.0). It shifts 150-200 rpm higher than my 2011 BMW 535xi with 8spd trans.
However, you can get excellent gas mileage in the R-Spec if driven conservatively. The photo attached shows the highway mpg I got on a trip to Wisconsin this weekend, with a mix of 65 mph and 55 mph speed limits. The photo shows the beginning of the trip, but near the end of the return trip where there was a little bit of slow, in-town driving, it still showed 28.4. :)
Nice!
