gpjlytham
Hi All
I have a 2011 Genesis 4.6l and the A/C was blowing cold when you were moving but at idle the A/C was not very cold (not as cold as my other cars) so i thought it must be low on R134A so i put some in and now i don't have any cold air. I have ordered a gauge set off amazon that should be here tomorrow.
On order: - OrionMotorTech 3 Way AC Diagnostic Manifold Gauge Set for Freon Charging, Fits R134A R12 R22 and R502 Refrigerants, with 5FT Hose, Acme Tank Adapters, Adjustable Couplers and Can Tap.
The compressor clutch is engaging but not disengaging.
I guess i might have put too much refrigerant in the system. It might be an expensive oops.
What pressure readings should i have on the high and low sides? If it makes any difference I live in AZ and we have very low humidity and crazy hot temps.
thanks.
thanks.
