Accelerator pedal stops working?
dtlinker
Genesis GV60
I have a 2024 Performance GV60 I have had for just over 2 months. I had an episode where the accelerator pedal seemed to stop working this week.
I was taking it for my first drive up in the mountains to ski. I was in Eco mode to save battery power for the long trip. I was on the mostly downhill return and had been playing a bit with the different parts of HDA 2 to see how they behaved, and was in level 1 regeneration, using the left paddle to slow down from time to time. I hit a flat section and wanted to accelerate, but when I hit the accelerator nothing happened at all! The road was empty so I tried various combinations of the cruise control buttons to see if it changed anything, but it didn't. The road steepened so I kept going, and after just a few minutes it went back to normal.
Any idea what happened? Is this something that I did or a bug or something that needs service?
Thanks
I ski all the time in Tahoe, which requires a 6,200-foot elevation drive. I do not have HDA 2 nor do I drive in Eco mode. I do not remember anyone reporting this issue but will be interesting to see the outcome. I hope it does not happen again.
Check under vehicle settings that you do not have speed limit assist enabled, this will prevent you from accelerating over the posted speed limit.
If you long press the HDA button on the steering wheel, it will activate the manual speed limiter, which will prevent the vehicle from exceeding a set speed of your choice regardless of how much you mash the accelerator pedal (this is the closest replacement for dumb cruise control)
it’s unclear from your post whether you observed other behaviours consistent with those two functions, but something to check nonetheless. Otherwise, if you’ve only had it for two months, take it back and ask them to inspect it, because that is not normal outside of those two conditions.
Thank you. I think I activated the manual speed limiter. At some point I was uncertain about whether HDA was on or off, and guessed (wrongly) that long-pressing the button would shut it off.
I do not need to take it in. I do need to read the manual more!
Thank you so much!
