After Market Battery Replacement 2023 GV80
Harleyhound
Genesis GV80
I must be "search challenged" because I can't imagine this topic not being previously discussed. I see the time coming when I need a replacement battery for a 2023 GV80. Dealer replacements are ridiculously priced if they even have one in stock and aftermarket ones seem to need alterations. What is the acceptable solution that you have come up with?
Her in Australia warranty is 5 years, so your 2023 should still be under warranty so would be supplied by dealership
It's 3 years here in the U S and they're trying to claim that an aftermarket camera plugged into an ignition activated accessory outlet causes the battery to drain. That's BS of course. The outlet has no power when the ignition is off.
This is what I did
