air whistling noise in the morning only
Philip2
My 3.3 T G70 with only 2000 miles on it makes a whistling noise from the undercarriage. Curiously it is only in the morning and starts after about 10 minutes of driving and is never heard before, even though I'm driving at the same speeds. It does not happen if I rev the engine in neutral. It does seems to be speed dependent.
It sounds like a high-pitched wind whistle .
One crazy idea is that it seems to start on my 4 mile drive to work when I start driving on certain roads. Could it be some kind of air whistle phenomena related to the road surface itself?
Did your neighbor say their cat is missing?
Roads can make noises. Try a different route to works.
Finally figured out my whistling noise. It is the outside rearview mirror. I retracted it while driving in the noise goes away.
I look at the mirror and see no rough edges or imperfections. This noise is very intermittent and probably depends on complicated aerodynamic factors.
How come no one else with a G70 is having this problem?
