The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
I don't know if I got the same gas pedal or not. I bought one that slipped over the top of the existing one rather than a replacement. It was as simple an install as you could hope for, but looks and feels very nice. I think all of the brake pedal covers you see install the same: remove the rubber cover from the original, than attach the replacement by positioning the bottom first with the clip behind the pedal, then rotating upwards until the top clips click into place. Both covers have remained well in place with no slipping, they feel fine, and look very good. I couldn't find a dead pedal cover, but ordered one for another model that hope will work. Won't know for another couple of weeks most likely.
Edit: This is the set I ordered from Ebay:
OEM Accelerator Brake Sports Pedal Pad Set For HYUNDAI 2015 - 2018 Genesis G80 | eBay
I should have posted pictures of mine earlier. Here you go. Note that the dead pedal is not part of the set, and in no way is a proper fit; however, it was a simple and cheap stick on solution, and honestly, once you pull your head out of the foot well, you can't see the top of it. Not perfect by any means, but I can live with it until I find something better.
Note that the dead pedal cover is woefully short, so I mounted it flush bottom. The brake and gas pedal have good fitment and appearance.
How hard was the install did it come with install instructions if so could you post them pleaseI received and installed them today. Not only they look great but I really love the way new accelerator pedal responds.
It’s way smoother especially when I start to push the pedal. On my original one I had to be a little bit careful to get really smooth start. On this one it gives really smooth acceleration which I love.
Sorry for the delay. I picked the dead pedal up from Ebay for about $12. Although it falls well short over covering the length of the existing location, I've gotten to where I don't notice it any longer. Of course, I'd still repalce it with a proper fitting one if I found such a thing. This link should be valid:Which dead pedal cover is that? Where did you get it?
Were you able to remove the plastic pedal and put the metal pedal on?I have a 2013 Hyundai Genesis 3.8 Track and the sensor went out I bought a new one but it's that black plastic is there a way to remove the plastic pedal and put the metal one back on?Hi guys,
I am very interested to get Aluminum Accelerator Brake Pedals for my car. I wanted to know if anybody already did that? Could you please share your experience? The look very good but are they comfortable too? thanks,
Yeah I was talking about the accelerator pedal I found one in the black plastic for $55 and want to take my pedal cover and put it on the plastic oneIf you are asking about the accelerator pedal, It's not removable. You need to get the entire pedal in aluminum version. But for the brake pedal you can remove the top part.
Is there away to remove the sensor and put it on the otherIf you are asking about the accelerator pedal, It's not removable. You need to get the entire pedal in aluminum version. But for the brake pedal you can remove the top part.
