Anybody else losing the side scroll bar on the main page of the 2015 forum?
Nikgen
It's been doing it most of the day and effectively locks you out as you can't scroll down to see the threads? I can only usually get in through the new posts tab? It loads and then does full screen and the right side scroll bar disappears - weird?
No issues here!
I've had where the screen gets wider in some of the sub-forums, where you can't get to the scroll bar unless you grab the scroll bar on the bottom and drag right.
Yes - that's what I'm seeing from time-to-time (never happened before this week). I will try to see if I can grab the scroll bar as you said next time. Thanks!
Yes - that's what I'm seeing form time-to-time (never happened before this week). I will try to see if I can grab the scroll bar as you said next time. Thanks!
It just happened again - but there is no scroll bar in lower right to grab. I just have to dump out of the browser and try again as refresh doesn't fix it when it happens. It's strange as it just started this week and it does not happen on any other website...
When the screen gets wider than will fit on the actual display, it puts a horizontal scroll bar across the whole bottom on the screen, it's not just on the right-hand side. Then you drag the slider button to the right to shift the screen left until you can see the right edge of the screen, with the vertical slider.
Happened again and there is no horizontal scroll bar either - very odd. Will have to see if it happens on other computers too. It only happens when I go into the 2015/2016 sub forum - not the main page (and only this website).
I can confirm I've seen it on some sub-forums and not others. I'm running Firefox on Ubuntu Linux, so my behavior may be different than yours.
Sometimes the problem arises when someone posts an over-sized photo. Then the entire page on which it appears requires sideways scrolling, and that could obscure the vertical scroll bar until you've scrolled to the right.
Nope, as I indicated above both the vertical and horizontal scroll bars are completely missing! It's happening in the sub forum main page - not in threads - so nothing to do with picture size!
