Everything (air filter, etc) is stock on the car. I changed oil (myself) at 3k, using a Wix filter and Mobil 1. Four months later the CEL sporadically came on and continued that way for four months, at which time it eventually became constant. I changed oil again (Wix/Mobil 1) at 10k. Took it to dealer, they scanned it and reported (quote from repair ticket):
CUSTOMER STATES CHECK ENGINE LIGHT IS ON CONFIRMED. I SCANED VEHICLE FOR CODES AND IT HAD A P0025- "B " CAMSHAFT POSITION-TIMING OVER RETARDED ( BANK 2) HYSTORY CODE. I ERASED THE CODE AND CODE DID NOT COME BACK ON. WITHOUT CODE BEING ACTIVE NO FUTHER REPAIRS ARE NEEDED
So they told me they couldn't do anything and to come back when it lights up again. It came on 2 days later (less than 80 miles), went to dealer 4 days later, and they reported:
CUSTOMER STATES CHECK ENGINE LIGHT CAME BACK ON P0025-"B" CAMSHAFT POSITION-TIMING OVER RETARTED (B2). CUSTO MER DOES NOT HAVE TIME OT WAIT FOR THE OCV INSPECTION. I CLEARED THE CODE AND RELEASED IT TO THE CUSTOMER.
Each time they kept referring to the possibility of the "sensor screens possibly being clogged/blocked."
And they started asking about my oil change history as they did not have records of my having it done with them - and once I told them I did it, they slammed me for not using a Hyundai oil filter. ("Oh, boy - here comes trouble" I was thinking). Now, I did use 5w-30w Mobil 1 both times and they started in on "you're supposed to use 5w-20w - that may be the problem!" Yes - it is stamped on the oil filler cap "5w-20w" - I missed that (but the manual discusses use of 30w!)
So I set an appointment to bring it back in a week for them to "check the sensor screens". I was told it was about a 2 hour procedure. When I got there, the service manager got involved and said it was not a 2 hour procedure, that they had to take the top half of engine off, they needed to order all the parts to do the repair, and it would take all day. You need to reschedule when we have time.
So I told them that before that major of a procedure was done, I was willing to change my oil to 5w-20w Mobil 1 - just in case. The service manager gave me (nice) a can of MOA to add. Both of us were hoping either the oil weight or the MOA would fix the problem. I had them reset the CEL - in hope it would not come on again!
That was 4 days ago. Now - about 90 miles later - the CEL is back on again.
That's my story - thanks for listening.
I like the loose connector theory . . .
