Automatic trunk not securing.
Tpr5.0
Press either the close and lock buttons and the trunk starts going down. As it gets to the point when it should go down the last bit, it stops. The tailights flash and the car beeps (not the horn) eight times. Repeated attempts yield the same result. Checked and there is no impedence. Have an appointment scheduled at the service department tomorrow.
Same problem here started in the last few days.
My vehicle is the 2015, 3.8 Ultimate. Although we sometimes get the flashing and beeping, we instead get no warning until we start moving. At that point the driver's display screen simply shows a trunk open graphic until we do something about the problem. We discovered that firm pressure downward on the trunk results in the latching process completing its task. I know, I know. I need to get into service, but the problem has been intermittent . . . an excuse for hours of wasted time in service with the inevitable . . . "couldn't duplicate issue." Ugh. I'm assuming the worst here, but service folks are as predictable as the tides.
Thankfully the fix was as simple as the mechanic resetting the electrical system. Trunk closes and secures with both buttons again. I believe what he did was toggle through the options on the screen between the speedometer and tachometer until he got to the reset section.
Thanks Tpr5.0
I figured I might try to get to the same reset section using these options screens. Never did find it. However, I did manage to toggle off/on my Auto-trunk. I also discovered that not only can I open the trunk, but holding the dash trunk button causes it to close . . . from my drivers seat. Who knew? Anyways, my problem is now solved, for now. Something as simple as forcing the mechanism to cycle may resolve this error. We'll see.
...I also discovered that not only can I open the trunk, but holding the dash trunk button causes it to close . . . from my drivers seat. Who knew?
Again, this is why I love this forum. You learn something new all the time. Thank You for this post techbeengood I learned something new today. :D
