Thanks!Yes exactly. Do. A mock up before you solder the connections
I am having same problems as everyone, do you remember how the wiring was set up for aftermarket camera to work with stock unit?I bought a camera on Amazon that attached to my plate and did rewire iit to the existing. Works great cost was less than $30
Find the connector for the camera and cut the wires and solder the new ones. Do a mock up before you solderI am having same problems as everyone, do you remember how the wiring was set up for aftermarket camera to work with stock unit?
so there is no "fiber optic" cable we have to deal with?Find the connector for the camera and cut the wires and solder the new ones. Do a mock up before you solder
No just power and video connections 4 totalso there is no "fiber optic" cable we have to deal with?
Great!No just power and video connections 4 total
Where was the loose connection at? The camera or the plug it's wires plug into?Back in 2010. My 2009 had this problem. It was a loose connection. Do NOT do this.
I put car in reverse with e break on. Opened and closed trunk I could see screen flash on. Then I pulled the camera and confirmed loose connection. Cleaned and reinstalled.
I had to replace my camera. I used this oneI just started to have problems with the back up camera. No display but the grid lines does show up. I got the head unit replaced two months ago. So I'm not sure if it is the camera or the head unit connection. No warranty on the car.
