Back up camera screen flickering on and off some times
martyk
I have 2012, V8, 4.6 Genesis that is still under warranty.
I have the 10 year Hyundai Platinum protection plan. I called Hyundai Protection office about the Back up Camera Screen flickering on and off some times and they said it is one of the items not covered by the warranty.
They pointed me to the Exclusions From Coverage section, item 14. In it, it says "Near object avoidance systems and all laser radar cruise control components". Does this mean the back up Camera?
I got a quote of $460 for the Camera and $395 for Labor from the dealer. To me this sound a bit to high.
Has any one fix or replaced their back camera. any help would be appreciate.
Marty
Suggest you get a quote from a local auto audio shop. These days they handle problems like this.
That’s very creative contract language on Hyundai’s part. I’m afraid they have you by the testosterones.
Does any know a mechanic in Thousand Oaks, Cailf. that works on Hyundai Genesis. I need my back up camera replaced?
Marty
Marty
Hello Marty. I have 2013 Genesis 3.8 (sedan). Having similar issue like yours. My display flickering and also my radio plays only about 10 second after turning on and then it go off. At the dealership they told me that I have problem with Radiohead or something like that, and that I have to replace it. I found used one on eBay for $200, and will replace it next week in local radio shop master. Will definitely update you with result.
Thanks for the info. Marty
You should also check out the YouTube vids about this issue.
I did, there was a guy that showed how to Remove and replace the new camera. It's a little bit to involved, for me. I found an Electronic place that was willing to order the camera from South Korea, and install it for around $500, $250 for the camera and $250 labor. That better than $770 from the dealer with 10% discount, and $648 from my local mechanic.
Marty
Take the camera apart carefully, clean the corrosion inside and re assemble. Usually does the trick.
I believe the camera is a sealed unit. Can not be taken a part.
Marty
I do have a brand new rear camera for my 2015. Used-car dealer bought it thinking it was fried. It turned out to be the harness in my trunk. I dont know if itll work for older gens but if it does ill be willing to let it go for under msrp.
2012 and 2013 use a different type of camera. Thanks any way.
Marty
