Baffled Rookie
AppleJack
Hello All,
Don't quite know what to say as I have a very strange situation.
I replaced a broken under cover front panel on a 2011 Gennie 4-door the other day.
Part # 29120-3M000. The part I received was an exact replacement from Hyundai as I laid the two side by side and they're identical.
Problem is that it seems there are only two threaded holes for the 4 screws I removed. Two screws went right in on the rear-most portion of the cover. But all of the other holes in the cover have no corresponding threaded places for them. As I crawled under there to look, there's nothing above any of the other recesses in the cover where the screws go.
I resorted to duct tape to hold up the front edge of the cover. Several pieces of tape along the bottom edge of the front bumper cover are holding it up for now.
What am I missing here? Were the other two screws just being held in place by the plastic cover itself?
Thanks in advance for any help/ideas...
Hello All,
Can you post some pictures to give us a better visual.
Hello All,
So you are saying there 4 holes in the cover and 4 bolts, but only two holes in the chassis to screw the bolts into?
Here is a pic of part:
http://www.hyundaioemparts.com/oe-hyundai/291203m000
What's most puzzling is that I can see on the original part where the screw heads had shined up the plastic a bit where they had gone through.
But "above" those two holes (they're closer to the front of the vehicle) there simply is no threaded hole!
What am I missing here!? I'll admit I've never worked on a Hyundai before, but I've been a mechanic most of my life and this one's got the best of me...
