steveinarizona
SUPPORTING MEMBER
- Nov 28, 2022
- Location
- Scottsdale Arizona
- Genesis Model Year
- 2023
- Genesis GV60
Thanks. Same place where by BMW had it.
While the first application may have been exhaust monitoring, OBD had been used for reporting & diagnosing just about everything with a vehicle’s powertrain for ~30 years.Is there an OBD port? OBD was setup for exhaust systems and we, of course, have none.
So went on a 600 km trip this week end and got to test the battery heater in -27C ambient. As I suspected with ambient temperature lower than about -20C the 6kW PTC battery heater can barely keep up with thermal losses from the uninsulated battery pack while driving. I was able to warm up the the coldest module in the pack from -15C to 10C after around an hour of preheating while stationary but once the car was on the highway it could not go above 12C. Which in all fairness it is still much better than arriving at DC charger with battery temperature at -10C.This would suggest the uninsulated battery pack looses thermal energy fairly quickly in winter highway temps . If travelling long distance in even relatively mild winter weather you kinda need to keep that battery heater on the boil most of the time. It will be interesting to see what -30C weather brings as the heating temperature differential will be relatively huge and may take 2 plus hours of preconditioning. I think if the battery pack is cold soaked there may be benefit to AC charging it before departure and hitting your first DC charger sooner than later to get the benefits of charge waste heating. Anyways I am generally happy with the results as I probably would have stayed 2-3 x longer and a least doubled my charging cost in my old Ionic 5 without battery preconditioning under the same conditions.
Is your issue that the car isn't showing that pre-heating is happening or that your charge rates are slower than expected? There is a lengthy list of reasons you could still have slow charge rates, despite having preheating engage. Unfortunately, a warmed battery does not mean fast charge rates.Anyone get pre conditioning to work?
I've only had it work one time. Noticed it because the battery lightning bolt changed something else and seemed to reach a higher kw at station.
Since then I've had no success. I set dc electrify America station as the destination but nothing changes on battery icon and can't reach anywhere close to 150kw or 350kw.
I know this sounds basic but is your battery precondition option box still selected in the EV sub menu?Anyone get pre conditioning to work?
Mine seems to be working and definitely does seem to substantially help DC charging speeds, although I have not yet attempted to DC charge below zero Fahrenheit.. Looks like it won't turn on until you are a certain distance or time from the charging station (makes sense). Not sure what the parameters are.Anyone get pre conditioning to work?
Certainly makes sense.This info was gathered from EV Odessey's video for the EV6. and recently reposted on the Ioniq 5 forum
It seems mostly relevant for the GV60 and mostly consistent with my observations.
Requirements for pre-conditioning to start are:
- Battery Pre-Conditioning has to be enabled
- DC FAST CHARGER set as a destination in the satnav
- high voltage battery temp below 21°C
- high voltage battery SOC at least 24%
- time to reach optimal temperature LESS THAN = travel time to charger ( I am not sure I entirely agree with this one)
- distance to destination less than available range
pre-conditioning will stop or not start at all if:
I have to note that my observations indicate that the temperature requirement for initiating and continuing pre conditioning is dependent on the coldest battery module and there interestingly can be a variation as much as 10-12C when heating the battery between the coldest and warmest battery module. The colder the initial battery temperature the larger the variation. This has implications in that the battery will also stop heating(unlikely) and the car will derate power output(possible)if the hottest pack gets too warm .
- Battery Pre-Conditioning is disabled
- HV-Battery-temperature GREATER THAN = 21°C
- HV-Battery-SOC LESS THAN =20%
- disable the navigation to the HPC
- Time to reach optimal temperature greater than travel time to charger
There is definitely a time or distance to DC charger requirement for pre conditioning. I am not sure what it is but I'm not convinced its as simple as "the time to reach optimal temperature( heater turns off at 21C but in reality ideal temp is not until 25C) is less than travel time to charger". When the battery is very cold it can take 60+ minutes to reach ideal temperature.
This is great info. Thanks!There is definitely a time or distance to DC charger requirement for pre conditioning. I am not sure what it is but I'm not convinced its as simple as "the time to reach optimal temperature( heater turns off at 21C but in reality ideal temp is not until 25C) is less than travel time to charger". When the battery is very cold it can take 60+ minutes to reach ideal temperature.
Outside of individual DC charger issues the main reason people don't get full rated speed is because the coldest battery module is not at the ideal charging temperature or your charging above 60% SOC. You really need to get an OBD bluetooth dongle and app like carscanner so you can actually observe that the coldest battery module has achieved 25C( optimal battery temperature) prior connecting to the DC charger. Just running your preconditioning for 10-30 minutes or more is otherwise complete speculation and it may or may not be sufficient.As one poster mentioned, the yellow glow spiral on the battery is what I've encountered 1x attempting preconditioning.
However it seems that the reason for not getting preconditioning may be because I usually go to EA stations when I'm under 20% SOC.
regardless of preconditioned or not, I have yet to be able to receive close to the full kw (150 or 350) even though I arrive to stations at 20 or less SOC. wondering if anyone else had this issue and a remedy for it
I can tell you on my car I've seen the battery conditioning light on my car turned several times on when the SOC was down around 10%.Requirements for pre-conditioning to start are:
What light are you referring to?I can tell you on my car I've seen the battery conditioning light on my car turned several times on when the SOC was down around 10%.
