Bluetooth Problem
rockymax
When my phone is connected via bluetooth, the call is disconnected after approximately 60 seconds whether the call is outgoing or incoming. Has anyone else experienced this problem?
Please define further...
1. Bluetooth hangs up phone after 60 seconds...
2. Phone hangs up after 60 seconds ( did you test with bluetooth off)
Sounds like a phone issue. Did you test another bluetooth phone? Whats your phone specs , is it jail broken ?
Ppp
iPhone troubleshooting:
"You're holding it wrong"......
"That is normal"......
"It will work properly with time and would be better if used more"......
Sorry, couldn't resist. ;)
It would be helpful to know what phone, opsys, rooted or jailbroken, and what BT version.
Had a Samsung ( older ) that was responsible. Try a friends phone that you know works in another car. I'm guessing its the phone. What make ?
AT&T in NYC is notorious for dropping calls when user demand exceeds their system capability...
It is an older Samsung. I will try my wife's phone. Thanks for the suggestion.
