Break in procedure 3.3 ?
Riley
No Genesis Yet!
As I do not yet have a car and may need to travel to find the right one, what is the recommended break in procedure for the new Genesis?
Thanks Gentlemen!
Here you go:
Re keeping your enging RPM between 2000-4000, tough to do on the highway unless you want to do 75+ MPH. At my highway speeds, I'm usually around 1500-1800 RPM.
I guess you could use different gears and it is only for 600 miles
You will be hitting higher rpm when accelerating too. You won't really have problems just normal driving. If cruising on the highway, just tap to a lower gear for a few miles. Avoid the full throttle high rpm.
Easy on the brakes too. Try to avoid panic stops.
