Brighter bulb for interior
shagnat
What bulb size/type etc. would I need to get a bright light(s) for the under the dash lights?
I don't wanna' do a bunch of modifications etc. Just a brighter bulb. Is it possible.
Also, wouldn't mind more light in the trunk and the glove box.
I changed mine to LED to match overhead. [ame="http://www.amazon.com/Cutequeen-4PCS-Lights-White-20-SMD/dp/B00B2HHDH8/ref=sr_1_8?ie=UTF8&qid=1390394488&sr=8-8&keywords=194+led+bulb+white"]http://www.amazon.com/Cutequeen-4PCS-Lights-White-20-SMD/dp/B00B2HHDH8/ref=sr_1_8?ie=UTF8&qid=1390394488&sr=8-8&keywords=194+led+bulb+white[/ame]
remember when installing an LED that if it does not come on then turn it 180 degrees and re-install. LEDs need correct polarity.
I replaced the trunk lights with LEDs (along with everything else in the car). This issue I have is that the upper trunk liner (not on the lid, but under the hat shelf) is sagging and blocking quite a bit of light coming out. I don't see a missing tab or screw mount anywhere. Is this just age or is there something I should be doing to prevent this sag?
Since 2013, cars like Acura Audi BMW Lexus and Infiniti have introduced their own factory equipped LED interior lights for their cars as premium package option. Not only the LED bulbs are much brighter but also last longer than the traditional incandescent bulbs.
My 2009 Genesis has factory LED's, but only for the map lights and dome lights.
