Broken Fuel Filler Door Lock Actuator
On a recent trip back from my son's school, I came very close to becoming stranded without fuel. The pin in my fuel door lock actuator had broken leaving me unable to open the fuel door. The electronic & manual release mechanisms still functioned, but with a broken pin, the door remained locked. Luckily, I had just enough gas to get home where I researched the problem and figured out the repair.
An obvious option would have been to take it to the dealer and let them figure it out. It may have been covered by the warranty. But then again, it may not have. The repair, though tedious, wasn't particularly difficult or expensive (about $75 for parts), so I chose to do it myself.
Figuring out the problem and the repair was a pain in the ass. I'm detailing it here for any current or future victims that may want to fix it on their own (or simplify their trip to the dealership).
The repair involves two parts: the lock actuator (required - it was busted) and the fuel filler housing (optional).
Part 1: Remove the actuator bolts.
To begin the repair, I had to first get the fuel door open. I used a rubber wedge to open a space, then used a screwdriver to pry the door open. It broke the tip of the acuator pin off, but I didn't care - it was already broken anyway. If you have a 90-degree pick tool, you can manually press the actuator pin in, releasing the door.
To get the broken actuator out, you need to get to the two 10mm bolts that hold the actuator in place. Unfortunately, they're hidden behind the fuel filler housing. You can use a razor blade to create openings in the housing rubber over the bolt heads and simply seal up the cuts with electrical tape when you're done. See the picture of the finished job to see where to do this. If this is what you would like to do, skip forward to part 2. If you want to replace the housing, as I did, read on...
To remove the housing, start by removing the four small plastic pins that hold the inner ring of the housing around the fuel tube. I used a pair of needle-nose pliers to simply pull them out. They got mangled a bit, but I was able to reuse them without issue. Next, you will need to get a small flat-bladed screwdriver through the four points on the edge of the housing to release the four clamps that hold the housing in place. The four little dimples on the housing mark the spots you need to poke through (see pictures). I used a drill with a small bit right on the rubber dimples to create the holes for the screwdriver. Use your screwdriver to release the four brackets and then wiggle the entire fuel door & housing out.
FYI the fuel filler door snaps into the housing, but you need to remove the housing to get it out.
Once the housing is out, you can remove the two actuator bolts and unplug the wiring harness from the back of the actuator.
Part 2: Replace the actuator.
To replace the actuator, you'll need to partially remove the drivers side trunk liner to get access to the manual release wire, which is held in place by a bothersome little clamp. Do this by lifting out the floor liner panel that covers the spare tire, removing the plastic cover over the trunk latch (2 10mm bolts and two plastic grommets), then the remaining 10mm bolt and two screws that hold the floor of the driver side liner panel in place. From there, you can peel the liner out enough to expose the area you need access to. I used a bungee cord to hold it out of the way.
There is a bracket straddling the stuff you'll need to get to, but it's easy to undo the two 10mm nuts and rotate it out of the way.
Now you can remove the old actuator and its manual release wire. In my car, the manual release wire was held in place by a bothersome little plastic clamp that also encased the existing actuator harness wire. I wanted to keep the existing actuator harness wire, so I ripped the little clamp out, tore it open and threw it out. The new actuator has its own release wire and clamp already attached, so no need to save the old one. I didn't bother trying to figure out how to re-clamp the existing harness wire.
Part 3: Reassemble
Once the new actuator is attached to the existing harness and you've snapped the manual release wire clamp in place, you can go ahead and bolt the actuator into place and test it. I sprayed some silicon lube into the actuator pin to make sure it functioned a smoothly as possible.
From there, it's just a matter of reassembling the trunk liner. If you chose to replace the housing, snap the fuel door into it, snap the housing into place and stick the four small plastic pins back into the collar.
Again, researching and figuring out the problem and repair was a pain in the ass. I hope this post makes the job easier for future victims.
Actuator part for 2015 Genesis Sedan: Amazon.com: Dorman 759-491 Fuel Filler Door Lock Actuator: Automotive
Housing: NEW Fuel Gas Filler Door Pocket Plastic Housing OEM For 2015-2016 Genesis | eBay
Just for anyone's reference, the item in the picture has a different connector than the original for my car. I had to cut the wires and take the old electronic connector from the broken one and splice the wires together. If you want to know, the original has a black connector housing instead of the white one shown. It's a small difference but will result in no fit.
Part 3: Reassemble
Thanks for the tips and the pictures, made a big difference being able to visualize what was going on!. Just replaced mine on a 2015 3.8 sedan. I was able to replace without taking out the trunk liner. I used a piece of string with a slip knot to hold onto the electrical connector then disconnected it from the faulty latch. Was a little tricky doing it by feel but look at the replacement latch before you start and it is easier to visualize. Once the electrical connector was loose you slide the manual handle in the trunk right up to the slit in the liner and this gives enough slack to work the faulty latch out through the hole where the fuel filler door goes. I then cut the manual lanyard on both units and connected the new one to the old pull lanyard with a jump ring. There are existing loops that make this easy. Make sure you secure the emergency lanyard before you cut it so it doesn't fall back into the body before you get it connected to the new unit. Then you attach the existing cable to the new unit and reinstall. Loosen the slipknot enough to pull it back out of the opening and you can snip it and the pull all the way back out. On mine the plastic pins around the filler pipe had center pins that you could back out with a philips head screwdriver part way and then pull them out. I was able to work the fuel door assembly out without first releasing the clips by just kind of jiggling it. Started with the drain hole to get a grip on it. Probably an hour for the whole job. Good luck if you have to repeat. Used the fuelman replacement part and it fit perfectly.
Thank you so much for posting this instructions. Worked great. Think my model had a different attachment for the plastic housing around the trunk lid strut - but I figure it out.
Thanks!
Curiously, after taking my 2015 Genesis into my dealer for the gas canister recall (twice - after the dealer's first attempt the engine warning light came on due to a miss-install), the fuel filler door actuator tip broke off.
The links that dbbalch provided at the start of this thread for parts no longer find their targets. Can anyone confirm that the parts needed for this repair are:
Hyundai Genesis actuator -- 81590-B1000
Hyundai Genesis fuel filler housing -- 81595B1001
Note: the production date for my vehicle is October 2014.
Thanks in advance.
