Burger Motorsports JB4 high performance tuner for Genesis vehicles
Status
Not open for further replies.
Please dont spread misinformation. Plenty of dealers can tell if a car has been tuned, regardless if you map it back to stock or remove the hardware before taking to the dealer. See VAG tunes, they all have this issue where the ECU will show how many times its been reset from stock (diff than just unplugging your battery)
The magsun-moss (sp?) warranty act does say that they have to prove that the tune is the issue, and some dealers will ignore and fix, some wont. The issue is that if the dealership wants to fight it, they have much more captial and resources to do so than you do. TLDR is if you tune, you are running a risk if something breaks IE turbo, manifold, gaskets, plugs. If you tune and your suspension breaks you can be sure they wont point to the tune as the issue (obviously)
does this require cooler spark plugs like the RC?
Unless they fixed the factory flaw you'll want to close the gap on the factory plugs to 0.022". I swapped the factory Stinger plugs for some $7.90 Denso 5346 plugs which appear to be a much better design than the factory plugs for higher power levels and have been very happy with them so far.
You are confusing the VAG GT1 flashing code (from loading a flash tune) with good VAG piggybacks like the JB4. Flash tuning is ALWAYS detectable. The EA888 JB4 on the other hand is undetectable but more importantly has proved highly reliable. It's one of the most popular tuning options out there for the the EA888 motors.
VW JB1 and JB4 Tuners, Intakes and Accessories - BurgerTuning.com
The modification being discussed in this thread is not a "flash" tune that rewrites the ECU. Your concerns only apply to them. The JB4 is a piggyback unit that modifies signals to the ECU and "tricks" it into adding more boost, fuel, etc. The ECU's factory parameters are still intact.
This is a little bit of confusion on this thread. The Magnuson–Moss Warranty Act does not apply to tunes. It only applies in situations where an aftermarket part designed to operate within factory specifications is used instead of an OEM part. This was to combat companies from forcing you to only use their "parts" on your car. For example, Ford can't deny an engine warranty claim because you didn't use Motorcraft oil and a Motorcraft filter. If you used oil that has a Ford certification and a filter with the correct filtration properties they have to honor your warranty. That aftermarket engine tune (flash, piggyback, etc.) is not "designed to operate within factory specifications" and is therefore not under the umbrella of the Magnuson–Moss Warranty Act.
Genesis Canada thinks they'd consider denying any powertrain-related warranty claims on cars running tunes.
The man has spoken, @Edmguy.
Don't tell me if you get a tune but take me out for a spin! :p
I appreciate the clarification, I didn’t fully understand the piggyback and how it works. I would like more information? IE how a piggyback could be fast enough(sending and receiving if it now has an extra step to go through) to be as reliable as a flash on the ecu?
Appreciate you clearing this up and expanding on it
The piggyback isn't trying to replace what the ECU is doing, just altering it so it runs off different areas of tuning mapping it already has. The JB4, for example, reads and alters the sensor signals at around 400hz, which is faster than the rate the ECU is reading those same sensors.
A piggyback can be as realable as the factory tuning as you're basically running factory tuning. Much less to go wrong compared to a flash map where safety systems could be inadvertently disabled or dampened. But, not all piggybacks are created equal. Having CANbus on tap so the piggyback can read all data the ECU sees is important to do it as safely as possible.
Curious, is it possible to see any fuel and timing maps with the datalogging? I would want to see just how much and where the piggyback is altering everything.
Either way, color me impressed for the features you get with a piggy back unit. I'll be keeping my eye on this one.
You can monitor AFR on both banks, fuel trims on both banks, and cyl1 ignition timing currently. Working on cyl2-6 ignition timing. Some JB4 logs here in the 3.3L Stinger thread: JB4 Stinger Logs!
Very nice. Thanks for the info!
This JB4 could be fun! At first thought on changing the plugs as recommended; not a big deal. But I just watched a video on how to change plugs on the 3.3T Stinger and it IS a pretty big deal since the intake manifold needs to come off. And I assume the G70 3.3 will be near identical since it's the same engine.
Wondering if there is any other option to changing or re-gapping plugs? Someone mentioned the reason for the plug change is not enough spark energy with higher boost. Is it possible to increase spark energy with the stock plugs using some other method and less labor?
Does the JB4 allow for 0-60 timing (or any other timing) since it has CANbus and can see mph?
Is the most we can hope for that this will NOT decrease fuel economy for a given driving scenario? Or can we actually hope for maybe BETTER fuel economy with the same foot on the pedal once you fine tune the tune?
The only question I have an answer to since I have experience with the JB4 on other vehicles is - fuel mileage increases. If you're flooring it all over the place and always in boost - you're going to use more gas. If you drive normally - most likely the way you did before adding a tune - you'll see better gas mileage. This has been the case with every boosted tune I've ever used - the only exception being if/when you install larger fuel injectors. However, that's not something you'd typically do without also adding larger turbos...
Economy is not changed during normal driving, the JB4 takes in pedal position and driving mode, among many other parameters, VIA CANbus, to incorporate them in to the tuning. We have a low boost valet map that may boost economy a bit. But, what fun is that? :)
The JB4 Mobile app has a 0-60 timer but if you want really accurate performance metrics this is the best option: dragy - GPS Based Performance Meter - Free Shipping in USA
On plug gap bottom line is that is the best easiest way to resolve the issue. It's about an hour job. In theory with flash mapping you could increase dwell which *might* get a little more power before regap is required but then you void the warranty flashing, and the flash tunes start at 2x the price of the JB4, so comes with its own drawbacks. And you'll probably still have to to the plug gap.
What are the performance gains going to translate to in the 0-60 and 1/4 mile times? I realize this would be a guestimate.
I was thinking if you can alter air/fuel and other parameters, this may allow better freeway mileage. But I guess you'd need a flash to change dwell and such that might more likely affect mpg. I'm a newb at tuning, so I don't really know what your box can do other than increase boost. And if all you do is increase boost based on the CANbus inputs, then it's understandable that you wouldn't expect better mpg and in fact, you'd be much more tempted to press the pedal and get worse. But as you say, that's where the fun is! :)
Regarding the plugs, if I found a reputable shop that was trustworthy and could do it in an hour or so, I'd consider it. But as others have said, it's hard to trust a brand new car to just any ole shop! I live in the San Francisco area, so I may get lucky with all the performance shops nearby.
Thanks Terry for your answers! much appreciated.
There is a video on youtube of a G70 beating several top dogs like the ctsv m3 and c63 in the 1/4 mile but no info on what was done with it, most likely a ton
Sauce?
A ton? With a piggyback...probably < 4 second car!!!
On the Stinger so far takes it from around 13.2@108 1/4 mile to 12.7@112 1/4 mile on the lowest map. I expect we'll see a JB4 powered Stinger in the low 12s soon though. :)
Status
