The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Map 2 is very noticeable on 91 compared to map 0(stock). Map 3 on 100 octane to me is also very noticeable compared to map 2 on 91. Maps 3 and 5 will def make you want to get on it throttle hard much more often right when you start using them. I daily map 2 on 91 and run 100 on map 3 going to the drag strip.Can you physically feel the power difference or is it only on paper?
What about E85 mix for map 5? Say 5 gal of E85 and 10 gal 91 octane?Two pages back, I posted two different dyno sheets running Map 1, 2 and 3, 5
This is Map 2 on 93 octane vs. Map 5 on mixed fuel ~97 octane
No don’t go the heavy on e85. 30 percent mix on a 16 gallon tank is 4.77 gallons. 4.5 would be safe I usually do 4 of e85 and too it off with 91. If you go passed the 30 percent mark the mixture will be to thick for the stock injectors to handle and the car will cut power to save itself. I tried 5 gallons of e85 and topped off with 91 and was having those issues at WOT constant added more 91 to delute the ethanol and bam she ran like a champI add 7 gal. of E85 + 14 gal. of 93 = 97 octane the G80 sport has 20.3 gal. tank
G70's is 16 gal.? so, I would put 7 of E85 + 9 of 91= 97 octane......or you could use BOOSTane. Ask Beefer, he's using it.
[/URL]
Correct. From what I’ve read and seen though it doesn’t seem like the injectors can handle more than 30 percent of e85. So an easy fix is do the math on your e85 blend and use BOOSTane for the amount of pump gas you will be using. Or go big and buy 100 octane at 8$ a gallon. Did that once. Map 3 ran better than map5 did. Both using 100. I have access to 110 and 114 if I really wanted to try but 110 is 24$ a gallon and 114 is 26$. Not exactly worth it to me unless I was fully bolted with pure turbo upgradesYeah, but you're topping it of with 91 octane not 93, so that would put you at ~95 octane, which according to Terry isn't recommended for running Map5...Map3 would be ok, though.
Thanks for the info man, I'm about to get a JB4. Also do I change my plugs? I'm only going to run 91 on this car. I live in LA, CA. So you're saying map 2 with 91 everything else stock is great for daily driving.. No problems should be stable right?Map 2 is very noticeable on 91 compared to map 0(stock). Map 3 on 100 octane to me is also very noticeable compared to map 2 on 91. Maps 3 and 5 will def make you want to get on it throttle hard much more often right when you start using them. I daily map 2 on 91 and run 100 on map 3 going to the drag strip.
You would need to change the plugs and gap them to .022Thanks for the info man, I'm about to get a JB4. Also do I change my plugs? I'm only going to run 91 on this car. I live in LA, CA. So you're saying map 2 with 91 everything else stock is great for daily driving.. No problems should be stable right?
I would definitely change the plugs out I did before I put the tune inThanks for the info man, I'm about to get a JB4. Also do I change my plugs? I'm only going to run 91 on this car. I live in LA, CA. So you're saying map 2 with 91 everything else stock is great for daily driving.. No problems should be stable right?
In that case just buy boostane and use that with 93 octWas looking at the option of mixing some E85 but unfortunately here in Arizona they’ve changed to E54 which could be anywhere from 60% to 82% ethanol. Not sure where to start almost seems like I would need a ethanol tester to test every time it’s more of a pain in the ass than it’s worth.
If you go this route (as I do)...get BOOSTane Pro.In that case just buy boostane and use that with 93 oct
What map do you run with boostane? Can it handle map 5 or only map 3If you go this route (as I do)...get BOOSTane Pro.
Map 3...never messed with Map 5. Happy where I’m at.What map do you run with boostane? Can it handle map 5 or only map 3
| Subtotal: | $164.99 |
| Discount: | -$33.00 |
| Shipping: | Free shipping |
| Payment method: | Amazon Payment |
| Total: | $131.99 |
I use the Professional version.Looks like BOOSTane is on sale right now for 20% off and free shipping. I guess I will bite the bullet and order a six pack at that price it only comes out to $.68 per ounce according to their chart would get me from 91 to a little over 98 octane.
Beefer how many ounces per gallon are you running?
