Cam sensor error
Dansdad97
Hyundai replaced my engine and tyranny at 68k. That was 13k miles ago. Now I'm getting a lower cam sensor error and tech claims; it's due to an oil change. Any thoughts it doesn't make sense to me. Thanks any feedback is appreciated.
Cam timing advance is controlled by oil pressure. If you are low on oil, used the wrong oil, or haven't changed it on time, it could cause some cam timing errors.
What is the exact OBD2 code that you are getting?
What is your oil level?
What weight oil did you use?
When (time and miles) was it last changed?
