Camera issue
Timothee
Hi, I have a ‘15 genesis 3.8 with 73k miles. My rear camera for some reason doesn’t work. When I put it in reverse nothing happens on my screen. Like I don’t get a blue/black screen or any change.
I tried everything from checking the harness (Hyundai bulletin), replacing the camera, playing with the settings, etc.. running out of ideas
Any suggestions are appreciated!
What turns the camera on? If the shift linkage hits a switch, I'd suspect it is not hitting or a defective switch.
If it is the computer, much more involved.
I'd check for voltage along the way, but my guess it is zero.
So the thing is, when I was playing around with the setting in the engineering menu and I uncheck Parking Assist 1 the screen will turn black when put in reverse with the lines displayed.
But parking assist 1 must be on since this is a DIS - Jog Dial vehicle. As per: https://static.nhtsa.gov/odi/tsbs/2017/MC-10125168-9999.pdf
Really not sure what the issue is here.
Ps. Tried installing a replacement camera with the other options and the new ones still didn’t work.
