beachguy
- Aug 20, 2021
- Genesis Model Year
- 2015
All power to my 2015 Hyundai Genesis shut off completely one day - no engine start, no dashboard lights, no trunk function etc. When I pushed the 10a battery fuse (as suggested) the power went back on shortly thereafter.
Power was good for 2 weeks, and then went out again. I tried pushing the 10a battery fuse again, and this time it sparked - BUT... the power still went back on and stayed on for 2 minutes (then went dead for good).
I found out there was a recall for my car with the ABS electrical / fuse being a problem.
I know there are other fuses on the battery terminal box connected to the battery, so maybe one of them is a problem? Although people say that if there is a spark I have a more general problem with the electrical system.
Any help would be GREATELY appreciated
as I don't know what to do or where to tow my car - I can't tow it to a dealer, which is 60 miles away.
- I had O'Reillys check the 8 month old battery and of course it was still good.
- I bought a replacement Micro2 10amp red fuse from Hyundai, but that didn't fix the problem
- Neither the original fuse or the new fuse looked damaged/broken.
But I called two Hyundai dealers and they said that the power issues related to the recall would only be in the front engine area, and that the battery connection with the 10 amp fuse in the trunk would not be affected by the ABS problem.VEHICLES ARE EQUIPPED WITH ANTI-LOCK BRAKE SYSTEM ("ABS") MODULES THAT COULD MALFUNCTION INTERNALLY AND CAUSE AN ELECTRICAL SHORT OVER TIME POTENTIALLY RESULTING IN AN ENGINE COMPARTMENT FIRE. AN ELECTRICAL SHORT COULD RESULT IN SIGNIFICANT OVERCURRENT IN THE ABS MODULE
