Car won’t start after new battery
Qamar ali
I have 2016 genesys yesterday I change the new battery but after that everything is fine but car does not start when I push to start it shows system check but after that it does not start can anybody help me
Your main battery cable is loose or disconnected in the battery terminal box.
All the cables are fully tight and nothing is loose but starter doesn’t click anything and also I check all the fuses are fine should I change starter
Before buying a new starter, I'd take the old one out and have it checked by an auto electrical shop. There may even be a place that will rebuild it much cheaper than going to a parts store.
Before pulling that starter or anything else you need to insure the battery is fully charged. You stated the battery was changed? How do you know it has a full charge? You could try a jump start and see if that will work. I do not believe your Genesis lighting up the dash is the same as starting the engine. Some more information as to how the old battery failed would be helpful and the problem now.
