Changing Seat and Lock Settings
jhunna1
I have a new 2013 Genesis 3.8 with the NAV screen (not the flywheel). I wanted to change the seetings for the door locks and also, when I turn off the ignition, the steering wheel moves out of the way, but the seat does not slide back. I think there must be a place to change those settings, but even my dealer could not figure it out.
Hi, I used my second key to program #2 setting to fully retract the seat etc..
You may need to separate the keys so one set is out of radio range..:cool:
To move the steering wheel up and out of the way, and the seat back:
from home go to "info/set up"
Then go to car settings
*Un* check the box for easy seat access and check the box for easy steering access (if avail)
I have the 2013 tech pack (with flywheel) so my GUI may differ
Gotcha thanks. I'm able to edit on my desktop but can't do it on the mobile app.
I take that back. I didn't realize I had another menu to use. Thanks for the tip.
I have a 2013 5.0 R-Spec (w/ flywheel) and the 'easy seat access' box MUST BE CHECKED in order for the seat to move back.
