Charging Genesis Sedan 4.6 Battery
Buddyforu
Do I need to remove the battery from the trunk to charge it?
No, just hook it up to the connectors under the small cover in the engine compartment. That's what it is for.
So you trickle charge using the same connectors used for a jump start?
Thanks for your help
Don't hook the charger directly to the trunk battery. Because there is a sensor(IBS) at the earth cable.
