Ok ok i know there are many threads about this topic but wait a min!!! I did a great job, took from me just about 1 hour with great results, well thats for sure genny is a very relaxing and quit car to drive infact quitest car i have ever own and driven. After doing alot of researches about sound deadening im realy got too much interested about that subject! So i thought i can make a great thing even better, Here is an easy way:
U need 1- screw driver 2- greatstuff expanding foam 3- a new set of thick floor matts 4- a thick carpet
How to do?
Remove the covers of front wheel wells, (its too easy) after removing you will see lots of spaces under that cover (sound eco can accumulate in these spaces) cut the thick carpet and fill big holes with it and then use expanding foam to fill all other spaces ( be careful to avoid some holes which are created to transmit water ) then put the well cover back in place, do same for other side. Next step is to add another set of floor matts on your existing (genesis matts) put for driver side too its not interfering with accelerator pedal at all, cut a part from thick carpet for raer transmission tunnel.
After finishing my work and waiting for couple of hours for the foam to dry totaly, i took genny to a ride...
Results: its not going to make you WOW, but you can feel a real difference, especially i can feel road noise decreased and its noticeable but not dramatic.. And today after getting bridgestones i felt even more reduction in noise,
Very easy work if you are interested to make sound deadening !
How to do?
