Climate control stuck in auto mode
1GEN
1G Genesis Coupe (2009-2016)
Hi everyone my name is lex thank you for having me here and allowing me to br part of a great community. My 2009 genesis 3.8 climate control unit is stuck in auto mode and I need to figure this out because my sons mom has heart problems and its quite hot here in Pennsylvania at the moment and when winter comes it will still ne bloging cold air im sorry forgot to mention its stuck in ac mode and I cant control ir or turn it off. I replaced the unit itself and also the ambient air temperature semsor thats behind the bumper check fuses and relays and from what ive checked multiple times there good, please please please help me thanks ahead for any help and or suggestions
Sorry fellas im having the most difficult time finding any info on this problem anywhere
What do you mean by it is stuck in auto mode? Does the display not respond to your inputs? Or do you really mean that there is no control of the airflow? direction? speed? temperature?
There are actuators that control where the air comes out and what temperature the air is. These can stick and fail. Have you made any attempt to test and diagnose the system? (Dealer level scan tools required.)
You can keep throwing parts at it, but it is often cheaper to diagnose instead.
Even in AUTO mode it should change with temperature settings. I keep mine the same all the time and have in temperatures from below 0 to over 100. So, are you saying it never adjust temperature or fan speed? At startup, fan should be high, but as it cools, will slow down. Does yours?
Given the parts already replaced, you may need a dealer diagnosis.
Sorry for late reply it does absolutely nothing but stay in auto and cant be turned off or controlled in any way shape or form same speed temp and setting, changed complete unit 2 times + ambient air temperature sensor, and still nothing also disconnected battery for 1and half hours to try and reset and nothing, I have an appt at the dealer monday the 15th im trying to avoid that if possible but time will tell thank you for trying to help truly appreciate it
Correct ir does nor respond to ant of my inputs I absolutely cannot use any button on the climate control unit
Well, there you have it. It’s dead, not stuck in the AUTO mode. The vehicle was built in 2008. It’s dealer service time.
Welcome. Moving this into our Genesis Coupe forum...
Um like I said 3 climate control units wer installed 1 being brand new that my friend from the dealer let me use as a test and thats after installing 2 used ones didnt really cost me much at all to do this which is why it was done and again I have cold ac stuck in Auto mode
I really think that you are at the point where paying to get it properly diagnosed is your best course of action now.
Well I have an appt on the 15th couldnt get anything sooner im just trying to brain storm whatever I can until that day comes, ? Would a failed climate control unit cause this or the in car temp sensor I read somewhere that there is a sensor to the left of the center speaker not sure. Thanks for all the help guys truly appreciate it immensely I need to get this done
No it does not it stays the same no matter what is done
Okay fellas sorry for the delay I have great news and information regarding this issue ive had for the last month so here we go
Took the genesis to the dealer on monday 349.00 for diagnosis and 4 mechanics scratching their heads lol bottom line I asked them and the service guy if this had a climate control module and the answer I got from all 5 people 4 techs and service guy was No its combined with the climate control unit now on here I found that it actually does have a seperate module so I get a call this morning and the service guys say hey guess what theres a module and its bad and I told him yea I knew that because my guys on Genesis Forum are awesome like that and thats what I learned from them. So bad climate control module just fof information purposes here the years and part number that will work for this issue.
Climate Control Module part#972553M500
2007-2014 all genesis use the same part certified guarantee. I want to thank all of you for your feedback and also for telling me to take it to get diangnosed got 3 recalls done a list of things that need to get done and also heating element inside the seat are shot found replacement seat for 191.00 dollars each in grade A condtion on partslocator.com all this for 5 days of diagnostics for $349.00 you definitely cant beat that I ordered the module for $65.00 dollars versus 1300.00 dealer lol. Thanks again for your help and expertise
Thank you for your input I appreciate it greatly it served me well
Your welcome buddy I appreciate everything you guys do here, the wealth of information is just priceless ill be back here on and off still have a small issue im trying to figure out ttys have a good night
Good morning to all my brothers here on genesis forum I would like to say thank you for your hard work and dedication to your service to thousands of people in need including myself its truly remarkable how much money youve save for so many I just wanted to take the time to let you all know that its aknowledged. Now im not sure if this is the spot for this but im still having am issue with the ac stuck in auto I have found out that the fan module is shorting out after being plugged in for 2 weeks and I just dont know how to trace that I did put direct power to the cooling fan and it works fine so my question do I have a short to ground thanks for any info
