- May 17, 2017
- Location
- Los Angeles
- Genesis Model Year
- 2025
- Genesis GV80 Coupe
Ditto that@TinsleyC based on the above I highly recommend you not shift into neutral when driving.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Thanks so much for your insight as a professional with applicable experience. Good stuff.Former transmission design engineer here (for off highway applications so my experience is not exactly apples to apples) though some of my former coworkers did transmission/powertrain design for OEM automanufacturers. I don't own a Genesis (though strongly considering) so I can't definitively say that they use the same hardware architecture, but on the applications I've worked there's a single speed oil pump that lubricates the transmission which is driven by the engine. So the faster the engine turns, the more lube oil goes the transmission. If Genesis does the same (which other automakers do), then when you coast and the engine gets decoupled and it's speed drops to idle (let's call it 1200 RPM) from 2400 rpm at 70-75mph (feel free to correct me if I have the wrong engine speeds listed) then lube flow to the transmission would drop by 50% but the ground speed still stays the same.
Neutral is a specific clutch engagement position where the output shaft spins but does not receive power from the torque converter. When in neutral the transmission still spins regardless of what the engine does so if the car has appreciable ground speed but little/no engine speed, the transmission can overheat due to lack of lube flow. This is the same reason why you tow FWD drive cars with the back wheels on the ground and why you tow RWD cars with the front tires on the ground (you want the wheels that aren't connected to the transmission to spin).
@Toddasaurus the feature in the torque converter (TC) you're talking about is the lockup clutch (LUC). In "converter drive" there is a speed differential between the flywheel side of the TC (impeller) and the transmission side (turbine). At low engine speed this speed differential creates torque multiplication and can help initial acceleration (TC output is slower than the engine flywheel) but at high speed this is known as convertor loss or drag (when you want the output shaft to spin as quickly as the engine but can't because of the fluid coupling). The LUC connects the impeller to the turbine to achieve a "direct drive condition" which engages (and disengages) when the TC output speed sensor hits a certain value. This makes the TC output shaft speed the same as engine flywheel. This can be seen almost like an "extra shift" but the feel may not necessarily have a pronounced feel. To try it, go into automode and let the car shift into 8th gear on it's own and keep the ground speed constant. You should see the engine RPM drop again (slightly) this is the LUC. The benefit of the mechanism is only realized at higher speeds to reduce fuel consumption so I'm not sure if the transmission software would enable LUC at anything other than 8th gear.
Thank you for the advice, well taken! This thought first came up when I had my Infiniti G37, it had a tremendous amount of engine braking when coasting. From 50 MPH on a flat road, it would slow to a crawl after about a block. In neutral, it would roll for several blocks. Fortunately I didn't do this much. Again, great info to know, thanks. I'll stay in gear.@TinsleyC based on the above I highly recommend you not shift into neutral when driving.
Hi,I have only seen my 2019 G70 3.3T coast once in the 4 months I've owned it and that was for about 5 seconds. I did the 13.5 S/W upgrade about 2 weeks ago and it sounds like it may never happen again...
Enjoy,
Carguy55
I don't think you're alone. I recall others also having issues with it never activating.In two years and 16500 miles I've never seen my G70 coast. Now to be fair, I'm not usually driving in ECO mode, but on many occasions over the last two years I've specifically tried to see if it will "enter Coast mode" (just as an experiment), but it never has that I can tell. Lifting slowly off the gas in ECO mode, on a flat road or slightly downhill without cruise control, at speeds of 50-70 mph, nothing. The car just slows down with no indication of coasting on the display.
I wouldn't use it anyway because i don't really see the value, but I am curious why it doesn't seem to work.
I wonder what other people's experience has been.
That's curious.Mine often says coasting in Eco mode.
Hmm. Wonder why we have different experiences and why Genesis would turn it off.... possible cause of some issue??That's curious.
I did update the software once about a year ago, which may have made it even harder to coast. Shrug.
pretty sure you have to activate coasting through the menus. It isnt always defaulted to "on"In two years and 16500 miles I've never seen my G70 coast. Now to be fair, I'm not usually driving in ECO mode, but on many occasions over the last two years I've specifically tried to see if it will "enter Coast mode" (just as an experiment), but it never has that I can tell. Lifting slowly off the gas in ECO mode, on a flat road or slightly downhill without cruise control, at speeds of 50-70 mph, nothing. The car just slows down with no indication of coasting on the display.
I don't want to threadjack and/or revive a dead thread but I cannot find any sort of messaging feature on this forum. I am prospecting the purchase of a new facelifted 2022 G70 and have a question for you Mr. danygenesis. I have read a couple different threads where you have chimed in that you run 87 octane fuel and commute a decent amount. I am curious what mileage you are at and if you have been running 87 octane the whole time? A follow on to this is have you had any mechanic issues that may or may not be related to the fuel you are running.I've owned my car for more than a year now. I drive almost all the time in Smart mode. in the flat roads of Florida and the car coats a lot
