Anyone use a Dashcam in their Genesis? I'm thinking of getting one as I live in a city with a lot of bad drivers. Any recommendations?
How is it powered? Is it a USB Powered? Where does power cable go?
Also bought the hard wiring kit I ended up with this one Rexing V1 3rd Gen 4K [url said:https://www.amazon.com/Generation-Dashboard-Recorder-G-Sensor-Recording/dp/B077B25H9K[/url]
Good choice of camera and hard wiring a must on an expensive car. Just so you make sure, whomever is doing the hard wiring, knows what they are doing. One wrong connection, a puff of smoke and you could have car warranty problems.![]()
Good point, good thing I'm a computer systems engineer. Also I noticed that the G80 when looking at the fuse panel has an on and off switch. Haven't seen that before on other model cars.
I had considered tapping into the front camera but: 1. you again get into possible warranty issues, 2. without a schematic which wire is which, and 3. My front camera is pointed in a more downwards direction than I'd think you would want for a "dash" cam.
I installed a Street Guardian dashcam in my G80. Installed it on the right side of the mirror assembly. Came with a GPS sensor which I installed on the interior right top of the windshield. Wired it to the fuse panel with a separate fuse kit. Wiring to the fuse kit is not straight forward since we could not put the wiring inside a panel running alongside the door. Took a little bit of tape to hide it along the seam but you cannot notice it. Best find an install video on Youtube for the dashcam model you want. Also, find the fuse that only activates when the car is turned on ( unless you want it running all the time) and stops power when the ignition is turned off. It was a wrong guess on the first try!
