Rey
I removed my MAF (mass airflow) screen 5000 miles ago, and can report no issues whatsoever. It is hard to definitively determine power and mileage increases, but I can report no mileage decreases.
The MAF screen resides at the mouth of the plastic air filter cover. Unlike GM products which are glued in place (and often require destruction to remove), Hyundai merely presses it in place. It takes five minutes to gently press it out - careful not to disturb wires in the MAF. It is even easier to restore.
I did a some research before I did this mod. I even bought a spare MAF just in case I had to destroy the screen for removal. Most of the research on the subject is through GM sites; where owners frequently remove the screen. Basically, the Genesis screen in the Hyundai intake tract is identical to the 2004-07 Cadillac CTS-V. GM introduced the screens on truck intakes with the view of a need to straighten airflow so the signal to the MAF wires would be uniform and constant. They continued this on to autos. Recently, it seems that GM has removed the screens on Corvettes, and perhaps on other models.
As best I can tell the screen restricts airflow at a bit less than 8%. I did not feel a power increase, but generally it takes at least a 10% power increase to be felt by one's "seat of butt dyno".
Lack of a MAF screen potentially can result in low rpm stutter and light throttle tip-in stumble because of tumbling air flow. At WOT (wide open throttle) airflow is comparatively smooth. I have experienced neither of these problems.
As for intake noise, it is very nice in my opinion. There is no hissing or honking intake noise. There is no intake noise at cruise or light throttle increase. At moderate or more throttle increase there is a motor sound, but that is even loud. My wife, who is very sensitive to noise increases, never noticed this change.
