Rey
I have done a fair amount of experimentation with a home-built cold air intake.
My critical measurement is the air temp. differential between outside air (dash temp gauge) and intake air (measured by a ScanGauge) at the mass airflow sensor. I zeroed the two gauges - they read exactly the same temp after the motor has cooled for a few hours.
I found that with city driving the variables are too great to get accurate comparison readings. This is especially true if the car sits in traffic when I have seen differentials approaching 60 degrees. The most accurate comparisons are made on highway driving where temps can stablize.
I found the stock OEM airbox is fairly efficient and delivers a temperature differential of from 8-13 degrees under most conditions.
When "designing" my cold air intake with a cone filter, I used part of the stock intake system - the part leading up to the OEM air box. This together with some sheet metal heat shields. I constantly monitor the differential and see anywhere from 3-5 degree heat rise with this combination.
I don't think there is much of a market for cold air intake systems; and even those on the market seem to sell in excess of $300. I cannot see much potential improvement over what I did at home for less than $60.
As for power increase, I have yet to dyno this car. May do so this summer. My impression of the Hyundai motor is that intake and exhaust are fairly restricted. Reducing these restrictions will no doubt increase power, but mileage will increase at a much lesser percentage because all you are doing is reducing pumping losses, which are a small part of gas consumption.
Nevertheless, on a recent coast-to-coast road trip at 5 mph + over speed limits (70-80 mph) I was consistently getting 27.5 mpg on regular 87 octane.
