DIY: Genesis 8sp AT TCM Learn Proccedure
jnc2000
NE Ohio / Pittsburgh
TCM is in constant communication with the control system's components (sensors and solenoids). If an abnormal signal is received for longer than the predefined duration, TCM recognizes a fault, stores the fault code in memory, and then sends out a fault signal through the self-diagnosis terminal. Such fault codes are independently backed up and will not be cleared even if the ignition switch is turned off, the battery is disconnected, or the TCM connector is disconnected.
Fault Diagnosis
Features a fail-safe mechanism that prevents dangerous situations from developing in the event of a transaxle failure.
The limp home mode engages if the transaxle malfunctions. In this mode, the transaxle operates at a minimal functionality level, making it possible for the vehicle to reach a service center.
Fail-Safe: Allows the vehicle to be driven safely in the event of a malfunction.
Limp Home: Maintains minimal functionality (*) in the event of a malfunction, making it possible for the vehicle to reach a service center.
(*) Minimal Functionality: Drive (fixed gear setting), Reverse, and Neutral​
Caution
• Disconnecting a sensor or an actuator connector while the ignition switch is in the "On" position generates a diagnostic trouble code (DTC) and commits the code to memory. In such event, disconnecting the battery will not clear the fault diagnosis memory. The diagnosis tool must be used to clear the fault diagnosis memory.
• Before removing or installing any part, read the diagnostic trouble codes and then disconnect the battery negative (-) terminal.
•Before disconnecting the cable from battery terminal, turn the ignition switch to OFF. Removal or connection of the battery cable during engine operation or while the ignition switch is ON could cause damage to the TCM.
• When checking the generator for the charging state, do not disconnect the battery '+' terminal to prevent the ECM from damage due to the voltage.
•When charging the battery with the external charger, disconnect the vehicle side battery terminals to prevent damage to the TCM.​
NOTE:
•Perform TCM learning after replacing the automatic transaxle to prevent slow automatic transaxle response, jerky acceleration and jerky startup.
• Adding automatic transaxle fluid.
• After servicing the automatic transaxle or TCM, clear the diagnostic trouble code (DTC) using the GDS tool. Diagnostic trouble codes (DTC) cannot be cleared by disconnecting the battery.​
