amartz
The latest possible update for this car was apparently 2018, and can only be done thru the DVD player. Anybody do this and still have the DVD set?
That's exactly what I plan to do, and it is the Tech model. And yes, it looks tedious thru the DVD playing. I've also been in IT for 45 years, so I think I can manage this, probably better than the kid at the dealership. From what I've been able to find, I *can't* directly order the DVDs. Only the dealer can order them, with a dealer code. Once you have them, is there any additional codes required to install? So GenSedan12, how did you get hold of the DVDs?I just connected to a charger and didn’t run the engine.
Was the install code specific to the vehicle, or the dealership? I wonder if it would work to burn a copy of the set. From what I could gather, the set was dated 2018. Not exactly current, but more up-to-date than what's on the 2012.I ordered the dvd’s from the dealer-parts dept. Service gave me the install code after I promised that I’d own it if it goes south. No idea what’s available today or if you can get the codes. I’ve done IT for 30+ years myself (Bernoulli drives and CPM) so you should be fine. Just follow the steps. I’m SURE you’re more qualified than anyone a dealer would assign to it.
When I looked on the webpage, it said dealer only.I think the code is VIN specific, so even with the discs, you need your own code. You can call mapnsoft maybe…
I'm curious what the dealer-part dept charged you for the privilege of acquiring the DVDs?I ordered the dvd’s from the dealer-parts dept. Service gave me the install code after I promised that I’d own it if it goes south. No idea what’s available today or if you can get the codes. I’ve done IT for 30+ years myself (Bernoulli drives and CPM) so you should be fine. Just follow the steps. I’m SURE you’re more qualified than anyone a dealer would assign to it.
Where did you buy the set? Also curious what the firmware did for you? Required to do the Map upgrade?I bought the DVD set last year. Little over $100 CAD IIRC. Part 1 firmware upgrade was lengthy but painless. Part 2 Map upgrade requires the dealer code which I have been unable to convince any local dealer to give me.
Ordered from dealer. The firmware did nothing noticeable.Where did you buy the set? Also curious what the firmware did for you? Required to do the Map upgrade?
