Does anyone know........
MADDMOE
NY NY
........Where i can get those Equus headlights from for my 4.6 Genesis i just love those LED lights they have running along the bottom of those lights and from the look of things it looks like the same headlight size and shape as the Genesis headlight assy....?
Doudt they will fit. Once the EQUUS is available, so show the part thru dealer.
they are the same headlights from what i can see as the Genesis but the wiring might be different but thats the least of my problems
I am not sure that you can split the housing, but if you can check over at the GTO forums as they have found strings of LEDs that they glue into the housing and then reseal it. It gives them the Audi or BMW look as they have even done halo look. I would expect that the Equus housings if they do in fact fit the Genesis will be very expensive. Over at the GTO forum it was all about getting the look on the cheap.
i went that route having my lights cracked open and having installed the halos and let me tell you no matter how hard you try to seal em back you will have a moisture problem with those lights, i dont know if you saw the headlights on the Equus but those LED's that light up along the bottom are hottt for those that likes LED lights, i'll keep searching some how some way i'll find out if they will fit or not
