does OEM 18 fit 5.0 Genesis?
Shady_panda
Hello all, does OEM 18 fit on 5.0 genesis?
I have a 2013 genesis 5.0 and someone from local is selling a set of 18s from 2015, I would like to know if the 18s would fit. I'm doing it for ride comfort not for looks, thank you.
Are those staggered rims?
So long as your bolt pattern is 5-114-3 you should be good to go.
5.0's have larger front brakes... might be a clearance issue since 19's are OEM.
do you know for sure or are you just saying that? I need for sure answer not a "might"
Wouldn't just be "saying that". Front brake discs are usually larger in diameter on the more powerful variant of the same car. Something else that needs to be checked.
I read elsewhere that someone can fit it, and then there are people say that it cannot be fit...so I want to make sure if people are just assuming rather than knowing for sure.
