Dome lighting help!
Charlesenslow
2 lights are out, 1 light dim, 1 light bright?
Do you have the Technology package with LED lights, or do you have standard bulbs? Either way, sounds like time to replace a few bulbs.
I didn't pay for the tech package. So do I have incandescent bulbs?
Do you have a touch screen NAV or a DIS controller located on your center console? Or a rare one is no NAV at all, which for the first Gen was only available without NAV in 2009 if I recall correctly.
Can anyone tell me how to remove the light covers without breaking them.
I'd like to know as well. Mine are starting to flicker a lot and the driver side is often pretty dim.
This is for the Genesis coupe, but I find it hard to believe that it's not applicable to the sedan as well -
I disassemble the rear lighting assembly to discover that the card that has three wires soldered to it connecting it to a circuit board full of all kinds of resistors transistors or whatever they are. It appears the only safe an effective way to remedy the problem is to replace not only the LED light for the entire circuit board.
