user0209
- Sep 13, 2012
I don't know how to begin to describe the problem. Basically, the keyfob sometimes could lock or unlock the doors as expected but most times the driver-side door's lock won't respond! Meaning the driver side decides to stay as is in its current state.
The button on the handle has the same effect.
So, when I cannot get it to unlock, I use the physical key; Or to get it to lock, I manually flip the button in the door's inside and slam the door.
I cannot figure out the pattern when it works and when it decides to stop working!!!
Is it a problem with the physical mechanic of the lock?
Or, some sort of error in the software logics?
Anyone got this problem? How would I go about fixing this? Thank you so much.
