Down size rim/tire
Quickly skimming this - I have 2012 premium/tech V6, got aluminum 17" with the standard size 215s (two standard size 17s in manual) for winter. Yes the front brakes are pretty massive which is why alloy wheels only (not steel). I should post photo, but away from home right now.
Just checked the Porsche 911 Carrera S, which is rear engine and RWD, and even it has larger disk rotors in the front.
I've never heard of any vehicle with larger rear brakes.
When you brake, the center of gravity shifts forward, causing a shift in front\rear weight distribution. The front wheels have significantly more load on them under braking, so bigger brakes are used to make use of the weight shift, allowing for more stopping power.
Note: You will not be able to fit 17" steel wheels over the brakes, but there are many 17" alloys that will work.
Including the OEM 17" wheels from the Genesis Base Trim model. Not sure where you can get them in Canada at a decent price. They go for about $200 used in the US, and there are plenty for sale.
