Downloaded the new software update for my 2023 GV80 via USB stick
I have not used my cruise since the update. Actually, I have never used this feature since I purchased the vehicle. I think I may not even have this setup.
Can anyone confirm that the newest update fixed the issue that was broken by the Oct 2022 update, as described below? In the manual (attached) it is referred to as "changing set speed".
Prior to Oct update, when using smart cruise control, anytime the speed limit changed, you would get blinking white up/down arrows in the cluster (where the cruise control info is located), which would be a notification that the cruise control was set to a speed that no longer matched the posted speed limit. You could then press the speed adjust switch on the steering wheel in the direction the arrows were pointing, and the cruise control would automatically be reset to posted speed limit. This feature quit working with the Oct update. I have attached a page from the manual that describes this feature. In the attachment, it is the part called "Changing set speed", not the "warning overspeed" which has already been reported as fixed.
I haven’t tested this yet, I don’t remember if i have seen this feature before.
Just downloaded the new software update for my 2023 GV80 via USB stick, so now have my Android Auto showing without that useless Android Auto screen and instead it populates with either my music or my google map. I wasn't aware we could do this and was waiting for an OTA update. No need. Just download the installer from the link below and follow the directions. Good luck!
Hey I found this while searching info on the update. I am downloading now to my USB for my 2022 GV80 and was wondering if I put the thumb drive in the USB data port. I am not computer savvy so sorry about the silly question. Thank you.
