aphillipe
- Jan 9, 2019
- Location
- Pacific NW
So... picking up a 2015 3.8 AWD hopefully Friday that's black on black with the signature and tech packages and has only 23k on the odometer. VERY excited.
I have some confusion on the DRL's and fog lights and have read numerous threads that only made me more confused! Seems like the 15's and 16's are different and folks have taken a ton of different strategies to achieve different looks. Hoping someone can address that and a few other things I was curious about before I pick up the car.
1) DRL's on the 15's; when is the LED strip lit up verses the amber bulb that also acts as the turn signal? If the headlights are on, are the LED strips on as well? Is there a way to isolate the LED strip and only have that lit up when headlights aren't on during the daylight hours? If I install OEM fog lights, can those also be wired in a way so that you have the obvious look I'm after which is white LED strips and white fogs being on as a DRL in automatic headlight mode? Lastly, if the amber is the DRL, is there a way to modify it so it's instead white or off entirely unless you turn on your turn signal? Trying to replicate how my Sonata was to an extent - fogs were DRL's plus there was a strip in the headlight assembly that lit up (although it was very faint).
2) Do the 15's come standard with the ability to use Android Auto/Apple CarPlay or do I have to do a software update like I did in my 2016 Sonata that shared the same navigation system?
3) Outside hitting Eco every time I turn the car on, is there any way to improve MPG in the AWD model like a cold air intake?
Thanks in advance!
Thanks in advance!
