Electrical w/out turning on engine
jwh2f
I apologize in advance if this has already been asked. I did a search and turned up nothing obvious.
In any case, last night I pulled into my driveway and after getting out of the car I noticed my sunroof was still open. The only way I was able to close the sunroof was to turn on the car (and start the engine) again. Is there any way to turn on the electrical system of the car without starting the engine (similar to turning the key halfway in a conventional ignition)? It seems wasteful to start the engine just to roll up a window or close the sunroof.
Thanks
Jason
If you don't press down the brake pedal with you foot you can press the start button twice and get the electrical systen on, close the sun roof and then press the start button once more to turn everything off.
Some things like the windows and rear shade will work after you turn the car off, so long as you don't open the doors first. The sunroof however needs to be closed exactly as mentioned by JOwest.
