Engine tapping knocking-Oil level is full
usmarine0905
Good day everyone. I have a 2012 Genesis 4.6L which i keep it up well and regular oil changes at the Dealership. recently I went out to start my car to take a road trip and the engine was tapping and what sounded like knocking. As I continued to listen, I was able to determine the bottom end of the engine was fine and not knocking. I was reading and many have stated to check the OCV, which I did. I pulled all 4 and tested them, cleaned them and reinstalled as the bulletin states to do. well, the tapping is still there, a little less noisy but still there, it will go away after about 15mins, but it never did that before. there are NO lights on nor any codes. could use any and all help in this matter. I am not driving the car until this is corrected
Thank you
Usmarine0905
Start with changing the oil with synthetic and filter again. Some of the dealers send their oil change to one of those jiffy lube.
The oil was changed at the Hyundai dealership 3 weeks ago, I was there waiting for it
I think that his point was that changing the oil is cheap to try. That dealer may have put the wrong weight oil in, which could cause this.
Other than this, I think you next step is to pull the valve covers off and see what's going on.
Joegr... Thank you for clarity. I will do just that.
You read my mind Joegr and worse case they did not change the filter.
I will be changing the oil and filter tomorrow afternoon... I shall reply back with the status
Sorry for the long delay, been raining day after day here. changed the oil and purchased filter from dealership and still no change. Anyone have any other ideas what might be causing this
With the oil changed. Does the tapping go away around 1500-2000 rpm or gets louder at normal temp.? If it goes away it could be your oil pump not having enough pressure.
After about 10 mins or warming the tapping goes away. when first started.. if I rev it up then No the tapping remains.
This post has twisted info -
Post in thread 'Valve lash/clearance adjustment? 3.8l' Valve lash/clearance adjustment? 3.8l
Okay well - I just realized that post is for the 3.8 engine. You have a 4.6 V8.
Well Joegr and Bemare.. I change the oil again with Quaker State 5W-20 and factory filter and that seems to have done it. starts up quite and runs quiet and smooth. 2 oil changes and it my baby again.. thanks to all that gave information and tips.. thank you thank you
Did you use synthetic or high mileage oil?
Good to know if it happen to my 2009 Genesis with 16,000 miles.
What oils did you use before that didnt solve the issue?
I have the same issue it just all the sudden started to happen I took apart the top-end valve cover and there doesn't seem to be anything wrong with the cams are valves it's a very loud noise sounds like a engine rod oh, I just don't get how it could just start over night. When I rev up the engine on the way down it makes kind of marble rolling together noise. When I unplug one of the injectors the noise goes away, which points to A-Rod I've Been Told. I have the valve covers off and everything looks fine oh, any ideas I know these engines have catastrophic failures and nobody seems to know the reason why
I have always let the dealership change it.. when it stated tapping etc it was after they changed it. 1st. time I changed it follow the advice from here I used the QS 5w-20 FULL SYNTHETIC and 2nd time I used the same, Quaker State 5w-20..FULL SYNTHETIC . she is purring like a kitten again
