Engineering Mode
I tried up down up down left right left right A B A B select start and my car got 50 extra HP!
Did the same as you but at the end I pressed volume up and volume down and got your 50 HP and my monthly payment went down by $50. :woot:
No fellas, stickers get you 5hp a piece. A pinstripe gets you 50, and a douchy license plate frame another 10hp a piece.
Hanging balls on your truck tow hook varies based on the size!
Don't forget circular tow hooks on sedans/coupes that get you an extra 25hp.
Window visors get you 10HP for a pair. If combined with the tow hook the gain is 25HP
How much do I gain if I use a hole saw and drill big ass holes in my rear bumper for better aerodynamic air flow?
For reals tho.... I can't figure this damn thing out.
Waking this thread back up.
Has anyone played around with this hidden engineering access? I have not had time to try it myself.
Wondering if anyone has found useful options to set (or turn off), etc.
Yeah but nothing of real value. Unless the Korean menus do something.
I would really like to find HDA and Rearview Monitor. Finding the performance gauge for Boost etc would be a bonus too!
Performance gauge? Isn't the boost bar shown on one of the screens between your tachs?
I don't have that on my USDM 6MT. Unless I'm dense and missing something obvious, which is a distinct possibility.
Maybe only Canadian 6MT then.
Correct. That page in the instruments is only with the "Sport" cluster, which comes paired with either the Sport Appearance package (which the USDM 6MT does not have) or the 3.3T engine.
Ah, I guess I'm spoiled. It would be cool if they could put those driving stats on the main screen
I got into the engineering mode, but the passcode that I used (time) didn’t work. Anyone know what the code might be other than what I’ve read?
With the new Map version? Which Map version you have?
Thanks. How did you get in?
Settings > System Info
Tap 10 times quickly at the bottom on the vertical line, then once on the bottom right of the screen.
Once I get in, it asks for a code, and from what I read before, the code was the time (typed in 24h format) but it keeps saying code is invalid.
I’m hoping someone with this version of the maps had figured out what the
