Enjuku Racing
- Jul 8, 2015
SNOW PERFORMANCE STAGE II
BOOST COOLER WATER/METHANOL INJECTION KIT
In Stock and Ready to Ship!
$599.98
The all new Snow Performance Stage 2 Boost Cooler® is the only water-methanol injection system tailored to your 2010-2015 Hyundai Genesis and other Hyundai Kia Turbo vehicles. Equipped with the new boost referenced VC-50 (1-50 PSI) controller, the Stage 2 will progressively command injection along the boost curve when water-methanol is most needed. Taking it one step further, the VC-50 controller has the ability to progressively command 2 Hyper-Sonic™ Nozzles independently of one another. This sophisticated injection strategy yields the highest increases in HP and cooling along all stages of the engine allowing you to greatly increase the boost & timing safely out of your 2.0T. Proven to deliver 50-80 HP and cool inlet temps up to 150 degrees! The VC-50 comes with a dual 7 color OLED screen and displays boost, percentage of injection, low level, and secondary nozzle activation directly on the screen. Utilizing a Snow Performance Genesis Injection plate no drilling is required of the intake piping and allows the location of 2 Snow Performance Hyper-Sonic™ Nozzles right where you need them. Complete with the industry leading Snow Performance 300 PSI UHO pump and Hypersonic Nozzles™, the Stage 2 promises to deliver the best atomization and power available in a custom package tailored to your Hyundai Genesis.
Kit Includes:
300 PSI UHO (Ultra High Output) Pump
3 Quart Reservoir
Snow Performance Hyundai Genesis Injection Plate
All Tubing Necessary for Installation
10' ¼ Inch High Temp Nylon Tubing
18" High pressure Boost Line
3' (Black) Wire Loom
VC-50 Controller
Pigtail Harness
2 1/16 Gauge Pod
Level Switch Upgrade
1 Nozzle Holder/Check Valve Combo
3 Hyper-Sonic™ Nozzles
Required Hardware Needed For Installation
Snow Performance Running S Decal
Comprehensive Instructions to Install on 2010-2015 Hyundai Genesis
Snow Performance 1-Year Warranty
