Everything dead!
Waki
Southern Ontario, Canada
This morning car started normally. ( 2009 TECH, 42K ) All audio, xm fm etc dead. No voice system. Only NAV visible.
This happened once before but cleared up. Any others with this experience ?? :confused:
Re: Everything dead 1
Many others with this experience. In fact, it seems to be the single most common mechanical failure with the tech package.
My '09 failed so often and for so long that it was finally bought back by Hyundai. If you have not already done so, take it to a dealer while it is still in failure and get it documented.
This happened often on 2009 Genesis'. If you turn ignition off, then back on again, the audio still will be off. If you let the car sit, as when you go for groceries, or go buy fuel, that at the next start up, if the car sat for over 5 minutes, you got all your audio back. Happened to me a few times. Dealer replaced the amplifier, and no more problems. Others with the same problem also got it corrected with an amplifier replacement.
Good luck.
Sarge is correct. If you are close to your dealer, drive direct to them, and DO NOT SHUT OFF THE IGNITION, so they can see what is happening. If you shut the ignition off, by the time the Service Writer and/or Techincian come out to take a look, and you restart the car, the audio will be working again.
36,000k warrenty on audio and DIS. This has happened to me a couple times... hasn't happened in a while though...
