EZ Oil & Filter Change on 2015-2016 Models (DIY Access Panel/Covers)
If you don't change it, you've got that much more dirty oil still in the car! I go to my old shop to get my oil changed because they pay me rent. Still, I can't see what the guy down stairs is doing!
If you don't trust the guy under there, you must know better!.. since you were in this business lol
I sold it in 1998, so only my managers are still working there. Just like any business, there are good employees and bad. When I owned it, I was watching a lot more than the current owner. Several times my employees said to me "How did you notice THAT?"
I know exactly what you're saying! I was in the fast food business for years.
Great write up.
Is there a direct fit replacement that will fit my 2015 3.8 RWD. I dont do the oil change myself. but every time I get my oil change from the Hyundai dealer, they always leave some of the retainer clips off although I remind the service person not to. Im planning on start using my friend to do oil change and the one with the openings would make life so easier. Where can I purchase a direct fit replacement with the openings for easy oil change?. Thanks.
Thank you!
A member in here (Carguy75) has a great writeup on these complete panels..
I found your article informative and am considering doing it, but I used to own an oil change business and we had a fluid extractor mostly used for gear boxes. I used it a few times for over fills too. But 1 time a truck came in with a bad plug underneath that looked to be a problem if we removed it. So I extracted the oil through the dipstick tube. I know how much oil it takes for that type of engine and I know that pulling the plug underneath leaves 1/4 to 1/2 a quart in the oil pan because the nut welded in the bottom of the pan sticks up. The hose from the extractor was able to go to the bottom of the pan and get more oil out than draining! The suction device has a marked reservoir showing the amount removed and I know how much I put in when I refilled it and it was more than what that engine takes by 1/4 a quart. I was impressed! It does remove the oil slower than draining, so solids have more time to drift down, but you are also pulling from the bottom, so maybe you're getting more solids. I didn't switch to using that as a method of oil changes. Many vehicles don't have a straight shot to the bottom of the pan from the dip tube. But that 1 vehicle was an eye opening experience that took place in the early '90's.
Keyser Soze is RIGHT ON TARGET. I made my own "oil suction extractor" from an old vacuum pump, a Gallon glass bottle and a rubber stopper. There is now need to get under the car and I don't get dirty. More importantly ALL. the oil is removed by sucking thru the dipstick tube.
You can keep feeding hose when the pump starts sputtering and you find a hew position to get it ALL. You never get that with a drain thru the plug. I built this device for $10.
In regard to the oil filter I always remove it from above even on the two occasions I pulled the under body panels. Using a 7/8" socket with a shorter extension on a 3/8" socket wrench works like a charm. Yes some oil drips out of the hole in the panel, no problem put your drain pan there. Again, I dont get dirty or go under the car at all. As the author mentioned in his EXCELLENT write up he has 40 years at this. I have been doing oil changes for 50 years including those when my father first taught me at 11 years old and you are all working too hard. This is the easy way, particularly on the Genny. I have been doing this on mine since new.
Thank you!
I ordered the rear panel for my 2017 G80 using the info from Carguy75's (btw, thanks Carguy75). Cannot remember the name of the place, but it's some dealership up in Illinois. Price was a little over a couple hundred. Problem was, they emailed me back to say there was a pricing change on the shipping charge due to size of the panel. So much that I had to cancel the order.
I think I'll try your workaround. I'm just a little apprehensive about getting the cut outs in the right places. The front looks pretty easy to reference from your pics. The next time you're under there could you please post how far back from the front edge of the rear panel your leading edge cut is? Oh, and thanks for your post!
....More attachments
Here's my attempt at the same.
I ordered the same parts that you did. Thank you btw!
I mocked up off a piece of cardboard and measured in 1" because that's the depth of the clips.
I used the cut out as a template, marked the location of the cutout with chalk and used some packing tape to secure it in place on the inside of the UBP.
I used a 2.5" hole saw and a dremmel cut off bit to cut the opening in the UBP.
In hind sight, I might have cut the opening about an inch to the right, but I'm still pleased with the results. I ended up not using the silver washers seen in the last picture. They really weren't needed. And I did not fill the holes left when I cut off the nibs on the hatch.
Also, I replaced all the bumper clips that have probably been missing since the first oil change.
I've got a lid from an old plastic storage box and I'm planning the same thing using the same clips for a hatch to the oil drain. I'll post pictures if that works out.
Good for you! That makes us both happy! You stick with your way and I stick with mine!! Maybe do a separate thread the way you prefer and let others decide what suits them best.
I noticed you can reach the oil filter from the top and there's room for a pan below the filter to catch any oil. I presently use the setup below to change the oil with an extractor through the dipstick. I purchased the oil extractor from harbor freight, but I had to pump it about 1000 times (not exaggerating) on my first oil change. I subsequently modified it with a venturi vacuum pump, also from harbor freight. It sure makes life easier on my oil changes, I don't even have to get the jack out or get on the ground now. If you go this route make sure to get the engine full temp before extracting to lower the engine oil viscosity.
You can reach the oil filter from the engine bay going from the top? Do you have the V6 or V8 engine?
Thanks! I thought about doing this since my 1st diy oil change when I purchased this car back in January 2020 when I found out that you need to remove the 2 whole panels for an oil change?! That sucked! Then, I joined this forum and ran into your thread about the panels you replaced on your 15' 5.0 and inspired me to look further into this. I figured that I'd try doing the small access panels 1st, since they had a separate part # from the complete panels, and if I would screw-up, I would then order them complete. Your thread photos really helped alot!..by giving me an idea to where the holes need to be placed and cut. Whould you mind if I add a direct link on my original post that whould direct our members straight to your thread, in case they need any additional info or even replacing the complete panels?
Btw, I wish I was still in my 20s, try mid 50s!🤭😁
PS I've been off work for the past 6 weeks due to foot injury and had plenty of time to do what I have done so far to my car. Back to work this coming Monday 😔
Of all the mods you list in your sig, which were your favorites? Which would you absolutely recommend to a friend who just picked up a genie?
I'd be tempted to do this since I already have an air powered suction device, BUT I just read an article about someone whose engine failed and it was going to be replaced by Hyundai at no cost to the consumer IF they could prove all oil changes had been performed. All of the DIY changes were not accepted, so Hyundai didn't pay anything for the engine. Spending the money to have someone else do it may be the cheaper way to go, depending on what happens in the future of your car.
Oil catch can
Ecu tune
Tcu tune
Atf cooler (particularly for warmer climates)
Request to follow me on Insta if you like or if you have the 3.8 to check out my mods.
Have some useful info with lots of pics @ bees_waxx_3.8
Very important information for DIY owners. Keep your receipts for the oil and filters purchased. The dealership will also have to show proof that the engine failed due to improper oil changes to deny warranty work.
If the engine internals are flawless and your oil change records are up to date then a dealership should not deny your warranty claim.
Tip: Never run the oil longer than the factory recommended interval even with full synthetic oil if the engine is under warranty. A dealership could use the longer than recommended oil change interval to deny your claim for sure.
ino this is an old post, but does anybody know the following info:-
1. the dimensions of the new AP/C for UBP
both.
2. can provide the measures of the location for cutting on each UBP.
i'm going to do this DIY mod
both.
Have you seen the photo attachments on post 1 & 2 in the beginning of this thread? This was done on my 2016 3.8 v6 RWD. If you have the HTRAC model the rear AP cover is different and the cut-out will be off-centered towards the driver's side for the oil drain plug.
If you're RWD you can clearly see where the cut-outs need to be on the UBP.
As for exact measurements, I never measured. But if you purchase the oem AP covers those will be your template to mark on the UBP, but the actual cut-out needs to be .5" inwards of the marking.
u
yes i guess im asking how big to make the cut outs and roughly where at.
I change my own oil and keep the box top from all of the oil filters. i mark the date and mileage on each box top.
