FAM module location
Qship
Ontario Canada
I've determined from research that my lack of DRL's comes down to the FAM module. I'm in Canada so DRL is mandatory by law. The high beams work so it's not the bulbs. Does anyone know where the FAM is actually located in the car? Not the fuses, but the module itself?
Front Area Module (FAM) is located in one of the fuse + relay boxes under the hood if I remember correctly. Open up the plastic box closest to the passenger seat. The FAM is a plastic rectangular thing mounted on-edge inside the box; it'll have a plastic lever/bail that holds it in position. It's physically about the size of a portable CD player. Disconnect the battery before removing the FAM.
Was your car originally a Canadian model - the US spec cars don't have DRLs.
mike c.
mike c.
Yup, it's a Canadian model. I checked all the fuse locations for wiring as well for DRL and its all there. Thanks for the location description. I'll take a look for it.
mike c.
Thanks Mike! Worked perfectly! Just unplugged the FAM and plugged it back in. DRL's are now working!
Yes I’m the fuse box on the passenger side it’s a black box with a lever on it
I have 2013 Genesis sedan and I found my FAM unit on the passenger-side engine compartment fuse box (just in front of the firewall. lift up the fuse box cover and the FAM unit will be the Nintendo-type cartridge to the far left.
